OD light blinking = overheated trans?
SHO Continental
Moderator
Northridge, Cali
On my drive last weekend out toward vegas I was playin with a 650i and had a sustained speed of over 100 for atleast an hour, going up and down hills, then I got that OD light, kept blinking, still blinking today. When it came on I was just thinking something with the trans was wrong, it was still moving though and we were miles from any town so we kept going at slower speed. Now the trans shifts hard into 2nd and 3rd.. it has about 13 hundred miles on it's current fluid. Did I overheat it?
The Gen 3s do that when the fluid hits 300F. Definitely toasted fluid if that happened.
Have you thought about replacing the factory lines with 3/8" hose. Makes a big difference.
SHO Continental
Moderator
Northridge, Cali
Is there a possibility it's just the fluid that's dead? Or is the trans also no more?
SHO#7
Cincinnati
Again... Pull the codes.
There are several reasons the OD lamp will come on. If the car set a trans over temp code, most likely it would have reset since you have done a few key cycles. You may have some improper gear ratio codes, or others.
If it is an overtemp code, you will have to get that fluid out of there asap. It has been overheated and will not protect the transmission as it should.
My bet is on TCC stuck off.
Edit: It is shifting hard because it is in a "safe mode" Line pressure is maxed out in that setting.
Mike
Racer X
SHO Pilot, Retired
Connecticut
O/D Off will blink because of an overheat condition, and will stop when temps drop. If the light is still on, you might have bigger issues.
Like the consensus says, pull your codes.
SHO M0nk3y
Edmonchuck, Ab, Ca
I am having a similar problem on my parents 95. Was on the highway doing bout 140 KM/H (~87 MPH) and some points higher, for a very short time hit 200 KM/H (~124 MPH), probably 140-160 KM/P (~87-100 MPH) range for 99.9% of the time on the highway while I was driving. I drove about the last 75%, my sister drove the first 25% and she drove about the 120-130 KM/P (~75-80 MPH) range. The o/d light started flashing about 40 minutes from home, was driving for about 3.5 hours and did stop for 20 minutes half way through.
I pulled the codes and got 628 - Excessive converter clutch slippage. Talked with my buddy who owns a sho and works at a ford dealer as a mechanic. Their tranny guy likes SHOs, doesnt own one but does know about them and said it most likely the oil pump shaft bearing is shot and wearing out the converter clutch seals. Also the tranny is shifting hard do to the trans failsafe mode, it upps the EPC (electronic pressure control) solenoid to max, so instead of the clutches and bands seeing 50 psi in drive, it sees 90 psi, causing the harsh engagement, because of the converter slippage.
So time for a rebuild but for the time being I do have another tranys out of another 95 that I will give to my parents to use till they can get a rebuild done.
The trany does have 245,000 KM (152,*** miles) on it and had a flush and something replaced about 40,000 KM (24,*** miles) ago (Cant remember what it was will have to look at the bill, i do want to say solenoid :shrug:).
SolidState
No Mo SHO
Toronto, Ontario, Canada
my O/D light blinks....then again, it throws every bad 6xx series code there is...
I think one of mine was something to the effect of max temp reached...hosed....
