shoguy311
When using a breaker bar on your lower control arm, remember to pull back your brake rotor dust shield when you are done. It makes nasty metal on metal grinding noise when you drive home.
shoguy311 said:Naw its my fault for not thinking about it. I didnt hear it until I got home and the noise was echoing off the buildings. I thought that I was having a rubbing issue with the tires. I finally parked it, found the tires had plenty of space and stuck my hand behind the wheel and bent them back out.
Did you get your tranny put back together the same night Mike?
F-22 Raptor SHO said:Yup....Brian and I got it together and running that night...well it was 12:15. I drove home the next day just in case.
F-22 Raptor SHO said:Car runs great. Smooth as silk clutch pedal.
yamahaSHO said:Aaron, did you get all four corners done? Sorry I had to leave so early. I really wanted to help you and Mike out more, but my parents wanted to have dinner then go to the car show.
Sign up on AIM and I'll have more pictures to post on the AzSHO website.
