no music, unplugged antenna
shooff1994atx
On my 4th SHO
Goldsboro, NC
I was fiddling in my trunk yesterday, and I think I disconnected the the plug that goes from the amp to the antenna. it looks like the female end of a rca cable. where does it connect? I was feeling on the power antenna motor and at the bottom there is a hole that feels like an rca hookup, but it will not go in. anyone know where this plug goes to?I cant stand driving without my radio.
naval-avi8or
Chesapeake, VA
The hole on the bottom is a drain for releasing moisture. Just follow the electrical connctor that connect to the antenna and its next to it.
NebraskaSHO
Harumph!
Omaha
It connects into the amplifier which is on the drivers side wheelwell underneath the trunk carpet. So my guess is that you need to either push it into the antenna or amp depending on which end got pulled loose.
Amp connections
TaurusAmpclose
TaurusAmp
shooff1994atx
On my 4th SHO
Goldsboro, NC
i know where it connects to the amp, I cant find where the other end connects..I can move the plug around and get stations, but once I set it down I lose the station. it has to connest somewhere by the power antenna, i just have no idea where..
naval-avi8or
Chesapeake, VA
I was just looking at the manual and it shows it pluging in the mast just below the body thru fitting on the side towards the rear of the car. The connector comes out of the mast and has a 90 deg bend downwards.
