No Crank No Start
WI93SHO
Eau Claire, WI
I stopped at a store on my lunch hour today, car running fine. I come out and it won't crank or start!
All the dash lights are working, windows roll up and down, just like normal. I definitely have power, but when I turn the key, no clicks, no crank, nothing.
It really feels like there might be a wire that came disconnected from the starter or something, the battery cables are fine since everything else works. The lights don't even dim when I try to start it, so there is no power getting sucked out from the battery.
I tried searches but it seems like everyone has a crank but no start condition, mine won't even crank.
Any help?
Thanks
93rev2sev
Hockeytown
You will have to use a volt meter (or a automotive test light) and see where there is power and where there isn't.
No clicking would indicate that the little wire on the starter may have fallen off. It's just a spade connector so you should have no problem reconnecting it...if thats what happened.
WI93SHO
Eau Claire, WI
Is that something I can check without jacking the car up? Where is it exactly?
The car is sitting in a parking lot right now.
Thanks
Edit* the spade plug is attached as far as I can tell (doesn't mean it's getting power, I have to test that). I got it towed home so I'll have to poke around this weekend with it, hopefully it's something easy!
FREAK_SHO
Wisconsin
When my starter failed, I had the same symptoms. Everything worked as descibed above, turn key, no click / click, nothing.
WI93SHO
Eau Claire, WI
Is it common for a starter to work one minute and nothing the next? Or do they usually die slowly?
And it is very wet around here with all the snow melting, would driving through a puddle screw up the starter at all?
Thanks
Mr Anonymous
Tire Wall
Thanks
Yes and yes, and yes.
Check the wiring, try the hammer test, and if all else fails replace the starter.
