92ShoOff
Hello everybody! I recently got my new motor all wired up and all and have been trying to get it started for the past few days. It's cranking over great, but doesn't want to start. I'm not sure if the timing is off, so I'm providing a video of me cranking the motor over and hopefully some of you experts can tell by listening if my timing is off. I'm almost 100% positive that I had all the came gears in sync with each other, with the crank sprocket and with the belt.... but I guess there's always a possibility I may have messed something up.
Also, when dropping the motor in I snagged a cable harness that was attached to the firewall by mistake. I didn't realize that it became snagged on the motor mount bolt as I lowered the motor down. There were no obvious rips of the wiring nor the conduit at the time but I'm sure I could've done some damaged there. This car has also had a history of starting problems. Two times that I've taken the car to AAMCO they've had problems starting it to test drive it and end up fixing some wires going to the CCRM if I recall correctly. So based on what you guys hear in this video, does it sound like the timing may be off? Or does the timing sound fine and should I maybe point my finger to some of this wiring? And where can I start with testing this wiring and all that? I'm almost a dummy with electrical but I do have a 12v test light
Thanks in advance for your help!
http://s11.photobucket.com/albums/a185/04LS1GTO/1992%20Taurus%20SHO/?action=view¤t=100_1798.flv
