Nav and CD player
FLIP-4-SHO
CA
After bringing my car home from Vegas I noticed that with the Nav the CD player is a one disk Player not the 6 disc changer. Just never noticed. Or maybe I just do not know how to load the rest of the disc's
markathome
2010 SHO
VA
If you have the Nav unit, you've also got the 10GB hard-drive.
Supposedly, you wouldn't need extra CD's loaded, because you would record your entire CD collection to the hard-drive, in a few years....
SHOrod
Torrie Tuned
Cedar Rapids, IA
Plus your player will play MP3 CDs so you can fit more than 6 discs' worth of music on one CD. Or you can plug a USB thumb drive/MP3 player in to the USB port in the center console.
-Rod
warden
Massachusettes
Unfortunately you can not copy a disc of MP3 to the hard drive. Audio CD's only and it is time consuming. I too was stupified when I tried to slip a second disc in there LOL.
FLIP-4-SHO
CA
I wonder if there is room inside the dash to put on. I would pay to have it in there.
warden
Massachusettes
I don't see why there wouldn't be enough room, but acquiring the actual unit is another story. I too miss the multi disc, I would have (6) discs of MP3's in there. The jukebox is not easy\time friendly to copy music to.
When I get some time (not likely anytime soon) I will be hunting for the second USB port inside the dash that is used for the SYNC Diagnostics and be putting a 80gb hard drive hooked up to that. THen I can still use the usb inside the center console for other music and for other passangers to bring along and still have access to all mine.
The other option I have been liking alot is playing via bluetooth from my phone.
gipraw
Pro Detailer
Cypress, TX
I just take 4 discs a day with me to work .. I get two on the way in and two on the way out .. If it isn't on the jukebox yet, then it is on the 80gb iPod in the console.
SHO U UP
SHO Guru
Virginia Beach, VA
Mine downloaded disc(s) to the car's hard drive pretty quick. If you listen to the disc while it downloads it, then it does take longer. Just pop it in, listen to a different form of music, and your disc will be downloaded in no time. ;)
