NAPA's HS54033 Head Gasket Set
DHMag
Free At Last
InCahoots, Texas
i am in need of an upper gasket set and my sources arent coming through for me at the time. i searched the forum and found this NAPA HG set. is this a complete upper gasket set ? could someone break down its contents for me ?
TIA
*EDIT* Napas part number is NGAHS54033
<small>[ January 01, 2004, 04:39 PM: Message edited by: DHMag ]</small>
Mr Anonymous
Tire Wall
I used one for a 60K last week and it has just about everything you need. I don't have a list handy at the moment, but basically it includes everything except injector to rail seals and injector to head seals. It does include injector o-rings.
91taurisho
my house, CO
2- Head Gaskets
2- Valve Cover Gaskets
6- Plug Well/Tube Seals
12- Intake Valve Stem Seals
12- Exhaust Valve Stem Seals
3- Camshaft Seals
2- Exhaust Manifold Gaskets
1- Throttle Body Gasket
2- Intake Manifold-to-Head Gaskets
2- Intake Manifold Primary Runner Gaskets
4- Intake Manifold Secondary/Butterfly Gaskets
2- IAB/IAC Valve Gaskets
6- Fuel Injector-to-Rail O-Rings
1- Thermostat Seal/O-Ring
1- Water Pump Crossover/Transfer Tube O-Ring
2- Water Outlet/Thermostat Housing-to-Head Gaskets
