MY SHO SUCKS!! PLEASE HELP!!!
Geoff93MTX
Princeton, TX USA
MY CAR HAS BEEN RUNNING LIKE COMPLETE SHIT LATELY. YOU CAN'T EVEN GIVE IT MORE THAN A QUARTER THROTTLE W/O IT ALMOST DYING. WHAT'S MORE IS THAT I CAN SIT THERE AND FREEE REV IT ALL THE WAY BUT IT TAKES ALONG TIME. WHEN IN GEAR DRIVING IF YOU FLOOR IT THE STUPID THING JUST BOGS LIKE ****. IT BOGS AT ANY MORE THAN 1/4 THROTTLE. I HAVE ALREADY DONE PLUGS, WIRES, FUEL FILTER, NEW MAF, NEW TPS, TIMING BELT, CPS, AND CAM POS SENSOR. iS IT THE FUEL PUMP? IT IA ALSO A BITCH TO START. IF YOU ALMOST GET IT STARTED THE FIRST TIME THEN DIES...THEN TRY CRANKING AGAIN YOU HAVE TO FLOOR IT WHILE CRANKING JUST TO GET IT TO BARELY START UP. I'M REALLY SICK OF ******* WITH THIS CAR CAN ANYONE HELP ME? PLEASE FOR THE LOVE OF GOD!!!
SHOemup
Dalton, PA
. Fuel pump. Dirty injectors. Have you pressure washed your engine perhaps. That'll do it. Just some ideas. look on the brightside. Once you get this fixed, you don't have to worry about all the other things you just changed.
<small>[ March 30, 2002, 11:21 AM: Message edited by: SHOemup ]</small>
V6&V8SHO
wauconda, IL
My guess is fuel pump. I bet once you fix your SHO youll be like "My car is badass". The SHO is a love it hate it realationship.
jcostantino
Coral Springs, FL
Can't stress this enough: First, check your codes!!! Then, once you've retrieved the codes, reset your computer!!!
Put a fuel pressure gauge on the schrader valve of the fuel rail. It should be:
Key on / engine off - 30-45 psi
Key on / engine running - 28-33 psi
You could have a worn out fuel pump.. they are inexpensive (around $90 for one from Autozone) and are a little time consuming to install but not difficult. Be sure to get replacement hairpin clips if your pump doesn't have them.
Jeff
90SHO1
Owego, New York
You really have to pull the codes. If not ready to do it yourself, find a good mechanic. Don't get into a science project w/o knowing what the engine is capable of telling you itself.
Geoff93MTX
Princeton, TX USA
Ya I know. I love it when it runs right. But I'm sick of working on this thing Damnit. I'll post what happens after I change it 2day.
That's a lot of work so far. But on the bright side there are a few really great SHO mechanics in Texas!
whfla1
florida u.s.a
Geoff93MTX:
without sounding like a wise guy...might i suggest maybe buying a new car ?
ribeye2065
