my sho cranks but wont fire
marz0821
ct
im not getting any spark. I have replace the crank shaft position sensor, dis module, coil pack, spark plugs, fuel filter, cam shaft position sensor, idle air control solenoid, battery terminals. still no spark, i hear the fuel pump turn on, im getting the correct amount of pressure at the rail ive tried starting fluid still nothing. any suggestion [email protected]
Phoenix
SHOHOLIC
QC , Canada
Couple things you need to check.
-The ground strap behind the intake needs to be attached
-Re-check the fireing order (use search button)
-make sure ALL 4 bolts are tight on the DIS.
ryan21288
Rhode Island
I just purchased an sho for $800 and its doing the same thing. crank no start. and im not getting spark. The guy said the car just died on him one day in the rain. Any Ideas? not sure if its getting gas or not
crystizel
