My car blows heat very weakly
shoguy3.2
London, Ontario
well guys, i consdier this an emergency cause going into winter and not having heat would suck bad.
when i have my heat on ....i have the dial up to high ..and the motor sounds like its blowing on high...like you can here the motor blowing stronger and stronger as you adjust the ranges ... but the air doesnt come out any stronger through the vents.
does anyone know what the **** is wrong with my car ??
i dont wanna spend any more money on something cause it still warms the car up but not like any other car...takes a while longer cause the heat isnt blowing strong outta the vents..also the air blows the same on all settings....ac, heat, defrost ...etc etc ...its not like heat is the only weak setting ..they are all like that ...
im thinking maybe a blockage somewhere between the blowmotor and the vents ? im hoping its something cheap and stupid like that. my car sat for 3 years stored away ... so maybe a mouse nest or something is in there....
can anyone give me any tips ?? or what to look for ?? maybe this has happened to someone else
any help would be appriciated guys..
thanx
SHOguy3.2
shoguy3.2
London, Ontario
ok guys...i checked under the windshield cowling by the air intake for leaves and stuff....and it was clean sooo thats not the problem ...any thoughts ?
shoguy3.2
London, Ontario
ok guys.....i have been gettin help over msn from ISHODU ....and he told me to check my AC ....and i did....the AC blows much harder then the heat does...AC blows like normal and the heat is very weak ...any thoughts..
i also ran the test to check the electonic componets through the digital display and it came up no errors soo all the sensors are working perfect ...AC blows strong...heat blows weak ..
any help would be great guys
teamentity
blend door
i would check out the blend door for shure.. whats most likely happening is that the door is not closing all the way and not allowing the heat to come outta the vents properly... thats why you most likely don't "feel" the volume of air.. you should have one main door motor, and possible a second one..
poffffd
