SHOhhhhMan!
Durrrrrrr.
Well, I just bought this 95 MTX with 72k on the clock and it ran great for the first week I had it. Well then I decided to do the de-carbonization treatment with some combustion chamber cleaner. I did that and it ran crappy after I let it sit for 30 mins. It eventually smoothed out almost completely after a day or so. So the other day I took it to the car wash and stupidly (I didn't know!) washed under the hood. I noticed it was missing when I left the wash and checked it out when I got home... sure enough, there was some water boiling in two of the front plug wells. I let it sit overnight and then pulled the two plugs and wires out after I was positive there was no water that would leak into the motor. Strange thing was it that there was this horrible light brown sludge on the connector side of the plugs and inside the wires. It was just like goo and it smelled like carbon/carbon treatment. So I cleaned off the plugs completely and cleaned the gunk out of the wires... put them back in and it ran great for about 25 miles or so. Then last night it started running like crap again. So I came home, parked it, checked the plugs and they looked fine; no gunk, no oil in the wells, and the plug wires were good too. I pulled them all out today and did the same cleaning routine as before but on all 3 plugs on the front of the motor. Took it out and drove it... ran fine for about 2 minutes then started to miss at medium to full throttle like it has been. It feels like it's running on 4 or 5 cylinders and sorta chugs like it starts firing on all cylinders for a second.
So I brought it home, read a lot of stuff on the forums here and am still kinda stumped since I just went outside and pulled some codes too...
KOER:
-225 - Knock sensor not detected during dynamic response
-536 - Brake On/Off circuit failure not actuated during KOER test
And these codes also showed up as Memory DTCs...
-157 - Mass Air Flow Sensor below minimum voltage
-528 - Clutch Switch Circuit failure
-542 - Fuel Pump secondary circuit failure control module to ground
And KOEO came up with 111 - Pass
So what's next? I haven't been able to access the plugs on the rear of the motor to check them. Should I just assume the worst and go buy some new plugs and maybe wires and get an oil change? (I'd hate to replace the wires since they're brand new from the previous owner.) I'm going to have to buy new plugs anyway since the car has AC DELCO plugs in it for some reason.
KOER:
