stephen newberg
I seldom use the slide function, mainly just using tilt, but I have used it a few times this summer and a couple of weeks ago it stopped operating in slide, refusing to open, though tilt was still fine. No sound, no relay click or anything, just nothing happening.
So, I guessed fuse, but in a check of the fuse lists, it was not obvious which it was, so I let it go and only got around to getting back to it yesterday. As a check, first I tried the slide, and darned if it did not work. OK, anyone have any practice with these moon roofs for a guess as to what is happening here? Ran it back and forth a bit and sprayed in some silicon lubricant in the area of the slides, as it could not hurt. Past that, I have no idea.
Thoughts?
pax, smn
Thoughts?
pax, smn
if you're not hearing any click or anything, sounds like electricity's not getting to the motor. Try removing the cover and see if the switch is getting power... and transmitting it.
