Kilty423
Sho-fer
Well i had a prior post where my car died out the blue. Well i went through it and i thought it was the fuel pump since it wasnt priming. Well i replace the pump and the car still wouldnt start. My buddy and I put a meter up the pump connector and there is no power. I also replace the ccm or whatever its called to see if that would do it and still no turn over and no power. Was told to suggest if a bad ignition switch in the steering column could effect some of this. Besides that any other suggestions would be helpful. Thank you
~Ryan
~Ryan
