Main Bearing replacement found and tested successfully!
bigro007
There's two types of Toyota mains, one with a single oil hole and ones with 3 oil holes. Not sure how to tell the difference between them. One set I had had 1 hole and one set had 3 holes. I wanted 3 holes in both of the end bearings so I just drilled 2 more holes in the end bearing that had a single hole. If you get two sets of the 3 hole bearings no drilling is required.
I can't find a lot of my pics for some reason, so the ones here show the single hole bearings. I ended up using the 3 hole ones though.
Hi
I was just looking the rod bearing and i was looking at the ford 2.0 or 2.3 liter duratec and they have the same journal diameter and the other spec are very very close did anyone has try some of those bearing?
bigro007
I tend to doubt it, as the rod bearings have generally been available over the years.
Hi again
i have check the regular ohc ford 2.0 liter and the rod bearing are indentical just a bit wider that all and tang is not on the right side that even closer than the duratec just sayin if the rod become obsolete then we could use something like that just saying
mavericksav
Moscow
Hi again
look for toyota supra 1991 rods
bigro007
hi
do you mean the 1991 rod bearing? or the complete rod and bearing?
bigro007
bigro007
hi
are the russian man who came up with this solution if yes very glad that you did is it possible to have all the photo
of what you did that is you have them still thank you
bigro007
RonPorter
SHO Club of America
Lake Orion, MI
These are the main bearings that he found a workaround for, as SHO main bearings have not been available new for many years.
Rod bearings have been generally available over the years, and people have been stockpiling them.
bigro007
you need STD. we used 0.25 cause we machined crankshaft. If yours crank is good - use STD
ok thank you
mary christmas to you all how in the **** you end up with sho in russia? did ford actuall sold taurus in your country ?lol
bigro007
mavericksav
Moscow
oh ok so you guy have imported these sho the way i understood it right?
Most of SHO gen1 and gen2 were imported in 95-2000. gen 1 is almost disapeared (I guess we have 3-4 in Moscow 2 of them is on road, 6-7 on road in all Russia). Gen2 are some more. Gen3 were 4 or 5 (red, silver, black, violet, maybe white) Red is still alive, black, silver, violet are dead.
bigro007
hi yes that is nice to know a bit of history of how those car ended up in your country and thank to have found a solution about those main bearing thank again
B-Aero
