Back side, meaning the firewall side? That would probably be one of the heater hoses. The 5/8" diameter hoses running from the engine thermostat area to the firewall penetrations to get hot water to and from the heater coils under the dash.
There will be a green or orange trail to tip off the leak source. Why don't you pop the hood after shutting off the hot engine and watch for the leak? It will be straight up from the first drips on the ground.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
