silver93sho
my 93 mtx has been down for about 3 months without a battery for maintenance, ive got everything back together and have triple checked all connections. i was attempting to do the idle air reset but have so far been unsuccessful. it will idle just fine for about 30-40 sec. and then start surging to the point that it stalls. prior to the start of this maintenance, this was a good running car, with overall good parts. i had no IAB problems before and i find it hard to believe that it got clogged/messed up sitting on a shelf. i continued to try the idle air reset for a whilem enough that the engine was good and warm. my question is this:
does the engine need to be cold for the reset to work properly
im not against pulling the IAB off and checking it and/or cleaning it but i really don't think that is an issue. im not sure of codes since ive pulled off the negative cable to sit overnite and then try again tomorrow.
Here is some more info: the car is still on 4 jack stands and the brakes need to be bled. the exhaust was repaired a while ago at a shop and they welded the y-pipe directly to the single exhaust pipe going back.So i had to cut the y-pipe off to remove it. i cannot weld and a friend of mine welded the y-pipe to the exhaust pipe but its not perfect and i am taking it to a shop to be done properly. so can the exhaust leaking add to the issue of the idle not resetting/stabilizing?
All relevant/helpful advice is welcome. i want my SHO back on the road!!!
