Little button on Gen IIs SHOs???
SHOTIME
Giver of life
Boston Ma.
I took a quick peak in blue.. didnt see it out in the open.. Can you help us out SHO bully?
"If it has wheels or a skirt, you can not afford it"
"Bottles are for babies, Real men get blown"
mailto:[email protected][email protected]</A>
http://people.ne.mediaone.net/billebobob/index.html
S
SHO bulley
Guest
well, he opened it. Its near the back. I guess it must of been aftermarket, whatever it is. There is like a button and switch. When he presed the button, the idle went down a little. Its obvious its not NOS...It had an alarm, could it be that?
Gez89SHO
LEGO SHO
NE Philadelphia, PA
Passenger airbag disable switch maybe?
Gezim
1989 Red
FordLover
Houston, Tx
Damn, all this time has gone by, and we just now figure out why the 92's are the fastest SHO.
yay for 92's with the unknown button.
-Martin
92 Silver UDP's, coneless, Alum SFB, SHOnut motor mounts
93 Green MTX, High Rev's Jr, lightened flywheel, grizzly paw TOB, fishtank lights, SHOnut motor mounts, K&N panel, coneless, SHOshop linears, tokicos, alum SFB, 26MM RSB, wigwag headlights, 225/55ZR16 firehawk SZ50's
94 Explorer Sport *sold*!!10-6-01
FordLover
Houston, Tx
Originally posted by SHOTIME:
Not on a 92 Gez... but nice idea
Keep 'um comming guys.. these little things can help.
And why not? the pass airbag was optional in 92, but I don't think most of them got it.
-Martin
FordLover
Houston, Tx
-Martin
p.s. I've been all over my 92, and no such button exists on, in, or near my glove box, well except for the one I installed, which is an on/off switch for my subwoofer amp.
gregr
Orange County, NY - USA
Security system Valet switch? I just dunno.
The BS flag was damn funny though.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
Nebraska SHO
Lincoln, NE USA
Seems to me that even though the pass air bag was an option on the 92 it was not legal at that time to disable it. I think!!
Could be wrong about that!!
So I don't think it has anything to do with the air bag. I would think though, looking at it, one should be able to tell of it is an aftermarket switch or a stock switch from the factory. I will check my 92 tonight.
SHOmuchFUN
Hinesburg, Vt., USA
It is more than likely a valet switch for an aftermarket alarm. I'm probably 90% positive. If you turn off your car, flip this switch, start it and then turn it off, it may disable your car if the alarm switch is still active. Thought I'd be the "mature" one of the group
Erik Engstrom
1995 ATX SHO
Shoside1
Eibach Springs/KYB struts
17" TSW REVOs
TOYO PROXES tires
PIAA 1900X platinum foglights
Pilot Motorsports Stainless mufflers w/
custom bent exhaust.
CUSTOM RACTIVE Superflow Intake
White faced guages
Eclipse/MTX/Audiobahn stereo
"SHODOWN" license plate
15% tint
TAURUS SHO window banner
Few stickers to add 15HP
WWW.NESHOC.com :) OR
http://SHOmuchFUN.freeservers.com
RickieFrat
La Cosa Nostra
State of Corruption - RI
I'm going with the alarm thery. I'm thinking its a "****" switch for the starter. Try starting the car in both positions of the switch and see what happens.
If all else fails. Follow the wires, and where they go !!!!
1992 TAURUS SHO **FOR-SALE**
Red/Grey Int
20% Tint
PIAA HeadLights
Boxless
1200 Watt System .... 131. DBs
Sig Pic By SHOTIME (THX)
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
www.fratsperformance.com
S
slosho
Guest
Originally posted by slosho:
Didn't you guys know? For the 1992 Production run Ford decided to have their engineers revamp the EEC-IV module to increase the performance over the stock programming. In the glove box they included a switch to flip back and forth between programs for the "conservative" driver. Too bad it was only on that "one" car! Wish mine had that option.
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
noSHO
ohio is for hustlers
I looked in my glove box and I found the button. I cleared out all the stuff I have in their to get a look at what it says, and wouldn't you believe it said "Press here to activate jet propulsion." I guess it lowered his idle to power up the little jets. Man all I need is a ricer wing now and my car will fly!
93ATX SHO OFF
Basehor, Kansas, US
Ask TedB, now that he's joined the forum...I bet he'll know...
AIM:FrdTaurusSHO
1993 ATX
K&N Cone
20% Tint
Lisesnce plates: SHO OFF
Pioneer 8000R CD Player
Police Interceptor Badges
Amber "Fishtank" Lights
GTS Blackouts
Colgan Custom Mini-Bra from CincySHO
IPT A-Pillar Gauge Pod with Autometer Gauges
White Filled Body Letering(Thanks to: Stallion's90SHO)
TransGO shift kit
8" Solo-Baric in stock enclosure
T
ThatSHOkid
Guest
did it run better?
1993 White/Tan SHO MTX 95k Miles
[*] Superwhite headlights, reverse lights, and license plate lights
[*] Colgan custom bra from Cincy SHO
[*] Windshield Banner that says "SHO" in Gen. 2 font.
[*] Superchip
[*] Blacked out "SHO" lettering
[*] Sho Shop Y Pipe
[*] Coneless & boxless
[*] Blazertech Super Clear 55w Foglights
[*] Sunroof Wind Deflector and Vent Guards
[*} GTS Headlight Blackouts (on order)
[*] Sony 10 Disc Changer
[*] Coming Soon:Tinted Windows, K & N Drop In Panel Filter (on order), Sub Frame Connectors, Strut Tower Braces
[*] All Possible Options
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
