Light Issues
ajdailey
NY
the cabin lights, underhood light, trunk light, and lights around the keyhole only work either right after the car is shut off or when the car is started. if the car has sat for a while, like more than a half an hour, and the hood/doors/trunk are open, none of them turn on. even turning the key back and putting it in auxiliary does not fix this. i've noticed this problem when my keyless entry failed recently, and i'm wondering if this is the same issue. any help would be greatly appreciated.
94 ATX 128,000
Sounds like the lights are only working through the delayed entry/auto lamp features.
The nefarious MFS is in the middle of all this. Horse
MelectroK
Michigan
The 30 Minute timeout delay? Bad door trigger or ignition signal to the module?
