Let's talk oil coolers...
J persons
Natchitoches, LA
If you go the route of remote filters and coolers, avoid Fragola fittings and lines as sold at Summit. These are the leakiest fittings I have ever used.
Cincinnati,OH
This had to have been operator error. I’ve used fragola and Summit fittings for 10 years. Their PTFE fittings are top notch. If you’re using rubber standard AN hose for oil. You should’ve been using PTFE.
J persons
Natchitoches, LA
Having worked in a shop assembling A/N fittings, I have extensive experience using Aeroquipt, XRP and others. I tried **** on the fittings, just snugging them up with a quarter turn. Nothing seemed to work. Do a Google search on 'leaking Fragola fittings' will show that I'm not the only one.
