Unfortunately, everything got rotated 90 degrees when they started putting the engines in sideways. On ours, the RH side of the engine is the radiator side, the LH side is the firewall side, the front is the passenger side, and the back or rear is the driver's side...The "right" and "left" orientation in the automotive industry, and its literature, is the drivers side is "left, and the passenger side is "right". This applies to the motor, and everything else under the hood.
Nope. Just remove the air tube betweent he throttle body and the air box for better access.Is it hard to reach/replace the ECT sensor closest to the firewall?
I removed nothing when I changed mine just used a 1" deep scocket and a ratchet. Easy! But you will have to drain about a gallon of coolant.RI-SHO:
Is it hard to reach/replace the ECT sensor closest to the firewall? Because I read that it should be changed every 100K or it will cause running rich problems, and it has never been changed in my SHO with 123K. I already have the sensor just wanted to know how hard it was.
I can add to that....Customer comes in a auto parts place and asks me for the headlight, in the middle in the back of the car. Figure it out?projectSHO89:
Unfortunately, everything got rotated 90 degrees when they started putting the engines in sideways. On ours, the RH side of the engine is the radiator side, the LH side is the firewall side, the front is the passenger side, and the back or rear is the driver's side...![]()
Steve
Yeah I though about what I posted this weekend when I was driving and realized I put the wrong end in my post sorry. shrugrangerj:
Forum members,
The following is intended to educate, not to be a wise guy.
Further, the "back" of the motor is the area where the transmission, or transaxel, bolts to. The "front" of the motor is the other end!
So, the SHO thermostat (T-stat) in question is on the back side of the motor, on the left side of the car.
Referrences to right or left that you find in automotive manuals and texts are oriented as stated above. (except in England, but then they call a hood a bonnet)
The easiest way to remember is to think of right, or left, as if your were sitting in the drivers seat looking out the front of the car.
Again, I am not trying to be a wise guy, but I think it is more helpful if we all have the same point of referrence when asking questions, and/or answering them. This is especially true when the communication is in writing. thumbs_u rangerj
