Leaky water pump, What am I doing wrong?
elarm1
Maryland Native
Woodbridge, Va
I changed the waterpump and all of the asosiated seals but the tube that runs through the block is still leaking like ****. What am I doing wrong? I need help!
SHO_DOODmorrris
Owner & Fanatic
Alberta
hey, i owuld check that tube again, **** up those o rings cause they tend to roll over somtimes or get cut up. lubing them should prevent this and make it slide in alright. if thats not the case did you scrape off all the old gasket on both the pump and the uhhhh.... fark i can tthink of it the thing it bolts to (not the block im not a retard the other thing) try that and LMK
elarm1
Maryland Native
Woodbridge, Va
Yes I scraped off the old gasket, lubed the O rings with antifreeze, and put a lil dabb of rtv on the thin o ring that goes to the block. Does the tube snap into the water pump?
elarm1
Maryland Native
Woodbridge, Va
Well time to tear her down again! Thanks thats what I was missing. Now it pops into place on the water pump side right
F-22 Raptor SHO
7015 feet above Sea Level
remove the water put and the down tube assembly and make sure the gaskets on the down tube are not leaking....also consider this: I did the same thing and found that not only did I use the wrong type of oring (it melted) but my freeze plug was desintegrating to the point where it was leaking. Ouch.
SHO_DOODmorrris
Owner & Fanatic
Alberta
orly? well thats ***
Storm-Chaser
Shit Louis
I've seen this as well (freeze plug problem).
I think this is going to be the next "problem" issue for some over the next few years, especially given the difficulty in accessing/replacing some of the freeze plugs.
Mr Anonymous
Tire Wall
Unless you have to remove the rear water pump housing, it's best to leave it in place when replacing the pump itself.
The 14-20 year old o-rings usually swell about 50% beyond their original size, and even with all the **** in the world it's still a good bet you're going to mangle that old o-ring when putting the rear pump housing back on. So if you have to remove the rear housing, just get new o-rings.
elarm1
Maryland Native
Woodbridge, Va
Thanks guys got the leak fixed. It was the o ring behind the water pump! She's good to go now.
SHO_DOODmorrris
Owner & Fanatic
Alberta
yeah your telling me... those frost plugs under the crank ventelation plate are critical... those leak and your screwed man, coolant in your oil = yuky lol
