elarm1
Maryland Native
I changed the waterpump and all of the asosiated seals but the tube that runs through the block is still leaking like ****. What am I doing wrong? I need help!
remove the water put and the down tube assembly and make sure the gaskets on the down tube are not leaking....also consider this: I did the same thing and found that not only did I use the wrong type of oring (it melted) but my freeze plug was desintegrating to the point where it was leaking. Ouch.
Unless you have to remove the rear water pump housing, it's best to leave it in place when replacing the pump itself.hey, i owuld check that tube again, **** up those o rings cause they tend to roll over somtimes or get cut up. lubing them should prevent this and make it slide in alright. if thats not the case did you scrape off all the old gasket on both the pump and the uhhhh.... fark i can tthink of it the thing it bolts to (not the block im not a retard the other thing) try that and LMK
