keyless entry codes
1shotime1
PA
Where is the code for the door handle keyless entry??? I know on some cars they are in the trunk, but i couldn't find it there. This is for my 97 SHO.
Thanks
1shotime1
PA
Alright....i saw that on thge v8 sho page but i thought it was for the code for the remote keyless....thanks
dugdog99
Charlotte, NC
you'll have to look up under the dash on the drivers side. right above the gas pedal is a white box with a bunch of wires leading into it. you'll have to really twist around, but on the side facing the center console there will be a label with a 5 digit code written on it. this 5 digit code is the master code. put that code in, then you have like 10 seconds to put in your own 6 digit code. atleast that's how it is on my 98.
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
dugdog99:
You can only put in a 5 digit code. No such thing as a 6 digit code. I think you are thinking of the 3 that comes after your code that will unlock all the doors. Putting the code in is like hitting the unlock button on your remote once. Hitting 3 on the keypad within 3 or 5 seconds is like hitting the unlock button twice. Hitting 5 on the keypad after the code will open your trunk. I like that, especially when I need to get into the car when my keys are not with me.
<small>[ June 04, 2003, 04:37 PM: Message edited by: 99V8SHO ]</small>
dugdog99
Charlotte, NC
mine uses 6 digits, the master code is only 5 digits, but you have to put in 6 digits for your personal code. i tried using only 5, but it didn't work. shrug
1shotime1
PA
Got the code today...5 digit number...I like how they added the all door unlock if ya press 3 and the truck open id ya press 5. Actually suprised me when I found that out!!! thumb
