K....last time...clutch.
bmcreider
Got Secondaries?
Fort Worth, TX
I need a new clutch, and it has to be around $300 or so...and it MUST last a WHILE...as in NO slipping, no rattling TOB, no constant "adjusting" and NO grinding when I shift....
I don't care if it's ******* the pedal or not, doesn't matter, I just want it to STICK and to LAST....no 10k mile POS if I am going to do it myself I only want to do it once....
So far I've found Valeos, that Clutchmaster stage 1 off of midwest SHO (although too expensive), the SouthBend Rally edition, and some clutches made my LUK and a Daiken clutch...
So which one? Clutchmasters Stage 1 ($400) Valeo (Under $300), SouthBend "Rally" clutch ($325), LuK (Under $300), or Daiken (Under $300)
Ishodu
Just go with a new stock setup and a ceramic TOB and upgraded release shaft bushings. This will last as long as anything under normal driving.
Dan H
Seattle
I saw an outfit with the CM stage 1 for around $335 the other day. I will PM you with the website.
For around $300 looks like your choices are pretty much CM stage 1, SB Ralley, or Valeo. I think the CM stage 1 is probably the best of the three, but also the most expensive.
