Chris Benvie
Every so often
Yes it does have the 255lph on it.SHOMurph:
I'm assuming you have the big fuel pump.
I'd buy the 15lb pulley from Vortch and the biggest John Holmes size K&N you can buy.
You should be able to hit 18lbs. Have Fred install Total Seal gapless rings. Texan Tony has been running those for a long time with no problems.
You got big injectors and forge pistons....go for it!
I'd also put some Nitto Drag Radials on the front or you are going to just spin spin spin.
It won't cure spinning but will help.
this all sounds like a good idea murph, although i'm not sure about 18psi, although it would be insane, i would like it to be SOMEWHAT drivable.
Once i get it all back together i'm going to start saving for joshs new gear set for the tranny and hopefully then i can step up to those numbers.
Axiantor, I will be contacting you once i get it back together, to umm... play.
Robby, its about right, maybe a little bit short, but its good enough for me. I still don't think it was tuned enough or correctly for that matter, but what do i know.
