munkee
Too busy...
Well, I finally got my 92 running, and more importantly licensed. It used to be my buddies car and it's been sitting since 2002. I had to replace the entire starting and charging system to get it to run, and then noticed that it was knocking, so I replaced to rod bearings. They were really wiped, I'll have to show pictures when I get back home. It's been running really great. It has suspension issues I really need to address, and it still needs some exhaust work. The only real problem it has is when you push in the clutch and the rpm falls more than 200-300 rpm to idle, it will drop down to about 400rpm and lug for a second before coming back up to idle. It doesn't throw any codes and it doesn't stall out. What should I be looking for? Thanks, Chris.
