Isnt this just my luck...`
smokin joe
Milwaukee WI
yeah my friend was just working on our other friends civic that was just turboed but wasnt boosting right well lets just say he got it to boost and apparently the owner of the car didnt fasten the vac line from the wastegate to the turbo correctly and yeah instead of dumping the unwanted boost it hit like 28psi and well it shattered all the sleaves and pistons, my friend was mad that it blew when he had it since he and i built the motor for that car and it was already a low 13 sec car without slicks but its an excuse to build a motor that will hold up to atleast 20lbs since it will prob see 15psi all day we just got done building the motor not to long ago either:cry: i guess it was really fast until it went SHOBOOM!!!!
phreaksho
Honda Slayer
Waukeshaish, Wisconsin
lol yeah that would suck.... hey if anyone is looking for a gsr motor i know one for sale full built puts about 270 without turbo *b18c5*
smokin joe
Milwaukee WI
what does he want for it? is it a gsr or type r because b18c5 is the type r motor
SHOBabe
mmmm SHO
Milwaukee, WISCONSIN
Bringetto said:
ah, dont give up :thumb:
the SHO is cursed. i swear.
then i thought i had it all set out. ran great no problems.
then someone slashes my tire. I found the tip of the blade in my wheel, he hit the rim
change it, thinking its all good then BAM!
someone smashes into it at a gas station.
:salute:
you poor thing... i feel bad for you!!!
hm... I KNOW WHAT ITS LIKE TO HAVE MY TIRES SLASHED!!!
only pathetic losers slash tires.
Its a power struggle, since they cant hurt they person enough, they have to take it out on an inanimate object that cant hurt back....
Wht91+
93 Green MTX
Oconomowoc,WI
Agreed :frown:
Wht91+
93 Green MTX
Oconomowoc,WI
B18C1 is a GSR and a B18C5 is a Type R. and My other car which is my new winter car has Vtec :rice: with only 20,000 miles on it. Thats all it will be good for :rofl:
phreaksho
Honda Slayer
yes sorry for the mistake it is the type r motor not the gsr motor im not sure exactly how much for it but if ur intrested i can find out tommrow or something **** be coming over to help fix the sho oh and is there any easier way to get the passenger half shaft out? i dont feel like disconnecting the exhaust to reach the bearing retainer bolts it broke at the knuckle so could i just pull it out from the knuckle? but then i would have to get it pressed in agian? not 100% sure on that just needed suggestions
FREAK_SHO
Wisconsin
Offer still stands...:) The truck is idling in the driveway and the trailer is attached.:rofl:
Dave
FREAK_SHO
Wisconsin
Not sure if this is what you are looking for but...
You don't need to remove the exhaust to get the axle shaft out of the car. The axles are not pressed in, in fact it is a slip fit. Just remove the lower ball joint bolt from the spindle, and the castle nut from the outer tie rod. Then seperate the tie rod from the spindle, and seperate the lower control arm from the spindle. You should be able move the strut and the spindle enough to slip the axle out of the spindle. At this point you can then gently pry the axle out of the carrier bearing.
Reverse the process to install new axle.
Good luck.
Dave
Wht91+
93 Green MTX
Oconomowoc,WI
Good luck.
Dave
Thats how I did it. It's easier to take it off with the Y-pipe out of the way but then you have to take out the starter.....wasted time. But it isnt necessary to take the exhaust off :thumb:
phreaksho
Honda Slayer
ok so this should make it easier then i dont need to even worry about taking it from the tranny? just need to remove the boot over the piviting part and pull it out from there? if i understood correctly if thats all then im almost done lol
smokin joe
Milwaukee WI
Well isnt this my luck............. I spend a good part of the day putting on my intrax springs and then waxing my car and getting it clean, and i go to my ex's house and park on the street like every other night, i come out to get something out of my car and it was at 11:30pm and i saw what i thought was a spot off Bird poo on my hood untill i step on something that crunches, hmm eggs f-ing people egged my car but im glad i waxed it i dont think it hurt the paint but its hard to tell at midnight in my present state as i washed it in her driveway at 12
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
That's a buncha crap... Do you happen to know who did it?
smokin joe
Milwaukee WI
Hard to say its the start of homecoming week i was in high school once and I did all the homecoming **** but i never do anything to anyones car no mater if its a joke or someone whos ****** for some reason but i dont know, its just stupid:bs: this is why i dont come home ever people in this town suck
Mrhappytuzi
Divorced from SHOs
Well.. ive messed with peoples cars.. but that was just a little bit of innocent foolin' around.. eggin a car isnt cool at all...specially when that car is a SHO.
