Hello all
I purchased a 94 SHO automatic about 6 months ago and been postponing signing up as i know if i did i would start modding this car witch is my daily driver(my toys are 2.3 turbo Fords..im a ex 5.0L guy)
but now i need help with something that i searched for on this board but in my case it doesnt make sence to mysellf
i cant determin witch of the 2 sensors this problem is. Car will start up in the morning and run fine. Sometimes after letting the car sit for short amounts of time after driving it will not start on the first try. Might take 1-5 or so trys but will allways start. This conditon has been going on for about 4 months. Sometimes also after it is started the tach will not work then flash on while driving. I pulled the codes with a $2500 Snap-on scanner 2 days ago and got 3 codes
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
336 (O,R,M) PFE sensor signal is/was was high - ">PFE
the 336 i think was an old one as it is not really related but wouldnt the CID one point to the cam position sensor but the isnt the loss of tach a crank postion sensor. I did swap out the DIS module for another one to rule it out but im lost. I really dont want to change the crank one if its not it and im waiting on the cam one as it is simple. No matter if i have a CEL or not or if the tach reads Zero or not the car will act exaclty the same once it is started(somtimes a rough idle for about 10 seconds). WOT there is no diffrence ever(just fast)
Thanks so much
Matt
but now i need help with something that i searched for on this board but in my case it doesnt make sence to mysellfi cant determin witch of the 2 sensors this problem is. Car will start up in the morning and run fine. Sometimes after letting the car sit for short amounts of time after driving it will not start on the first try. Might take 1-5 or so trys but will allways start. This conditon has been going on for about 4 months. Sometimes also after it is started the tach will not work then flash on while driving. I pulled the codes with a $2500 Snap-on scanner 2 days ago and got 3 codes
Thanks so much
Matt
