Introduction and what I’m working on
14TR
Pennsylvania
Both engine mounts 100% done. Now the engine, trans, transfer case, and both driveshafts bolt up 100%. Any fabrication for the drivetrain is completely done! Thank god lol
14TR
Pennsylvania
Here are the resized pics
14TR
Pennsylvania
Finally was able to get the remote oil filter setup together. The biggest issue was, believe it or not, finding a threaded male union that is M20x1.5 on both sides.
I ended up having to order a hydraulic bulkhead connector for $30 with shipping. Cut off the long side, clean up the thread that I cut, then drill out the pass through hole as it was only about 3/8”. I took it up to 1/2” which is greater than or equal to the smallest orifice in the fittings/filter head anyway. Once that was done, the hoses were routed to the remote filter head location on the driver side inner fender. This is a good spot as there will be some protection from flying rocks etc provided by the inner fender itself. It also give enough vertical clearance I can get a larger than stock filter in there such as an FL1A or larger
meSHOhorny420
Oregon
Hey why pay three times as much for crap that lasts 1.5 times as long?
These were my last three Bauer purchases, and I'd recommend them all. I also bought the cordless shop vac earlier this year, but it sucks (no pun intended i wouldn't recommend it).
4735
14TR
Pennsylvania
I have a drill, 3/8 impact, 4 inch angle grinder, and the corded surface conditioner in Bauer. Can’t complain about any of them. I do wanna pick up the battery powered ratchet though
meSHOhorny420
Oregon
My only regret is not buying the cordless ratchet sooner. Should've bought one years ago. I'm using my 3/8 impact way less now.
14TR
Pennsylvania
Some progress on transmission control. I had considered using the the stock sho ecu to shift the 4r44e transmission via paddle in the ranger, but figured for my purposes (racing) full manual control would be preferred. So I went about programming an arduino to handle manual shifting of the transmission. Once actually installed in the truck it’ll interface with a relay board that will switch the shift solenoids and a potentiometer will allow full manual setting of line pressure. Here is a quick video showing the bench testing of it, using LEDs to represent the shift solenoids. Once actually completed I’m going to have a small TFT screen on the dash to display current gear selection and line pressure
Brumfield780
