Lots of frustraition here! My '97 SHO has been stalling intermittently. It is totally random -day, night, hot, cool, full throttle, idle, just random. It will either stall or act like it's not getting fuel or spark in and out. After it stalls, I have to crank it 5-10 times to restart. Other than that, it runs fine. Factory PCM programming.
Here is what I have looked at:
-TPS: good voltage curve.
-MAF: good voltage/flow rate readings, good baro and load.
-Engine: no vacuum leaks, good compression and leakdown.
-Fuel pressure: 35-40 psi idle-load.
-All temp signals: OK
-Fuel trims: OK
-IAC: OK
-CKP/CMP: good signal.
-EGR/DPFE: OK
-O2s11/21: good crosscounts -OL.
-No misfires, faults. No codes.
Is there something I am over looking or something else I should be looking at? Any help is much appreciated. This is driving me nuts!
-Fuel trims: OK
-IAC: OK
-EGR/DPFE: OK
