HI guys, new here to the site and hope you
all can help.
Picked up a 92 5 spd SHO last summer and have
yet to drive it more then a block. Last owner couldnt fix it, so now its my shot.
Im familiar with working on cars, which helps but this one is stumping me.
Car fires right up and I let it warm up a few
minutes. Hop in to drive and power it intermittent.
It will take off fine then fall on its face..off and on.
For fun, I installed a new coil pack, cleaned the crank position sensor and checked the gap, installed a new TPS sensor (which it really felt like) and none of that stuff made a diff.
I then dropped the y pipe about an inch thinking maybe the main cat was plugged. That didnt help.
When it does this I can put the car in nuetral and try to litteraly try to rev the motor up and even then it doesnt run right and feels and sounds supressed.
Go to drive it more, and for about 20 feet, feels normal, then goes back to no power at all. Wont die but just enough power to get it off the road.
No CE lite as of yet.
My next guess would be maybe a bad fuel pump with low fuel pressure and or maybe MAF sensor.
But figure Id at least get some sort of CE lite if it was
the sensor.
Any suggestions and Im all ears.
thanks
Dg
all can help.
the sensor.
thanks
Dg
