Randy Harmer
Can anyone give me a answer to why my 93 3.2 will start missing 2 of it's cyls once in awhile?
YES THE IDLE DROPS AND I HAVE REPLACED THE COIL PACKprojectSHO89:
When it appears to drop two cylinders, does the tach also drop by 1/3?
Steve
What are the condition of your motor mounts and subframe bushings? Some members have found while accelerating that the motor moved enough to strain the DIS connector enough to cause a bad connection. Make sure that it's tight, and are any of the DIS connector retaining tabs broken?projectSHO89:
Then your problem is either an intermittent connection between the coil pack and the DIS or the DIS itself is defective. We've had a few forum members with this fault over the last year and, as I recall, the DIS was the culprit in those cases.
Steve
Uh... where's the DIS?Randy Harmer:
masho95:
Steve
Look on the passenger side of the intake manifold. There should be a grey colored module with two connectors going to it, and the letters DIS on the front.Randy Harmer:
