thxone
Bugs
Ok so the first code that pops up is 551 "Intake Manifold Runner Control". Apparently something is wrong with it but I have no clue what it is. My memory codes are for the right O2 sensor, one code says it was lean, the other code says rich... it's the same O2 sensor. The last mem code was for the EGR. This is all that pops up when I read the codes.
Ok, so how do I fix the "IMRC" or diagnose it? What is it? Where is it? I thought about it... Control, so it acts on something... Q: what? A: The intake runners. Q: How? Well I had to think about that too. The runners have a vacuum control on each side that opens the butterflies. A: By vacuum. Ok so I got that far and I thought some more... A: Locate and trace the vacuum lines from those runners. I did and they terminate at a T fitting that connects to a device behind the TB on the intake on the runner side (Inside) Q: Is this the "IMRC"?
Can this Control module be cleaned or serviced?
All Symptoms this 1995 ATX SHO is showing:
1. When cold - Drives great albeit with very firm first to second gear shifts.
2. When cold - Smells a little rich.
3. When Warm - Check engine light comes on.
4. When Warm - Anything more than a quarter throttle makes the car sluggish until almost 4,000rpm then it hauls ****.
5. When Warm - Smells very rich.
6. When Warm - If I give it full throttle it acts funny when it shifts... kinda like it is thinking about it. Does not do this when cold.
7. When Warm - Does not always want to fully kick down on the tranny and go go go...
8. When Warm - Check engine light comes on... goes off... comes on.......
