Instrument cluster
Scott 99 SHO
Haverhill, Mass
Hi,
I am having a problem with my speedo and tach are going haywire, I know one of the symptoms is the ABS module, that has been changed and is working fine. I also have changed the right ABS sensor. Would a another sensor cause the tach and speedo to mess up. Also could the cluster itself be a problem. The vehicle shifts fine so no issues with trany. If anybody has any ideas please let me know.
Thanx Scott :thankyou:
Izzmo
SHO Enthusiast
Kansas City, KS
Speedo and tach? Usually that wouldn't be a symptom of a bad ABS module, so that kinda sucks you had to replace that.
I'm just speculating, but you might try replacing taking the cluster out and seeing if everything looks right. In my old '99 Sable I used to have, my tach would act all weird and replacing the cluster fixed that.
Someone with more insight on this should probably answer though.
