Installed ARP studs and a Cometic gasket
Shamwow
Michigan
Here are a few details on the lovely SHO source ARP head studs and cometic 3.2L gasket.
To start, note that the gaskets are not symmetrical. If you place them upside down, you will port a cooling passage into an oil passage!
Correct:
747D7B8D FD71 42E9 8A99 D7E872CDCAB6 zpsuwh7qwte
Incorrect:
F27FC23C 2766 4BD5 B8E2 4012C543B939 zpsg84s9ngl
The studs are pretty straightforward.
You can install the studs first then drop the head on or the head first and then place the studs in. In either case, normal practice is to bottom the studs, then loosen them 1/8 of a turn. They should be loose.
94D9A667 13C5 412A 9415 348D28432607 zpsmgkepomf
One thing I noted is that the ARP washers are a smaller diameter than the SHO washers. This spreads the load over a smaller area on the head, which is bad.
The 2JZ arp studs (2jz head virtually identical to the SHO head) have this same issue and most everyone recommends using the stock washers. So you will want to re use the stock washers.
You will need a deepwell 12pt 1/2" socket (3/8" drive) to install the nuts onto the studs. A mid length socket might work. A standard short socket will bottom on the tip of the stud and you wont be able to tighten the nuts.
There is no issue installing the studs, washers, or nuts with the cams in the head.
Other than that, i followed the stock torque sequence and used the following torque stages:
1) torque all to 35ft-lbs
2) torque all to 50ft-lbs
3) torque all to 65ft-lbs
4) torque all to 80ft-lbs
These torque values are with ARP moly ****! This is the recommended thread ****.
I chose 80ft lbs for two reasons. First,
My engine builder/mahinist recommended 75-85ft-lbs based on the diameter and length.
Second, the 2JZ guys (which use a similiar length stud with same M11 thread) use 80ft-lbs and thats the ARP recommendation for that motor.
Now to finish up the timing belt, fuel rails, and intake. Thanks again SHO source for these great products.
1E4300EB EB07 4A8D 8BC4 F0363E69B4B0 zpsslcpsjiu
That victor Reinz in the top photo looks like oem material. You can buy that brand at NAPA and other places. The Cometic at the bottom looks different. Maybe I'm wrong...
Shamwow
Michigan
There are three gasket pictures, all of the same cometic gaskets from SHO source. They came in Cometic packaging from Cometics address.
You can see that cometic appears to manufacture the gaskets from victor reinz material. Or perhaps subcontracts VR to produce them. Victor Reinz is generally good stuff in my experience in the Nissan world.
The installed picture is the same gasket coated with copper spray. Its probably not necessary but old habits die hard.
Shamwow
Michigan
Only 4-6psi in our endurance racing application, so not sure how great of a test it will be. We just wanted a little extra insurance
yamahaSHO
E85 whore
Arkansas
I've always bottomed out head studs. ARP says to do this as well. http://arp-bolts.com/p/FAQ.php
I personally would have gone to 90-95 ft-lbs. They used to specify 80 for the Subarus and found it not to be enough and that block and have revised... and is nowhere near as strong as the SHO block. I am curious to see what these will do in Zach's motor as it will be pushing more power than any SHO, ever.
Shamwow
Michigan
I thought about doing a bit more torque but i didnt want to warp the head. We will see how they hold up!
B-Aero
