Turbo Exhaust ******
Grand Rapids, Michigan
I recently installed catted downpipes from stainless works, and when i was removing the stock catalytic converters from the turbo, one of the studs pulled out with the nut stuck on it. i checked out the threads on the stud and they didnt look great, and when i checked out the turbo side as well, whoever had installed it previously had cross threaded it. what should i do? i ended up putting a smaller bolt through the hole and clamp it with a nut, but just so i could limp it to a shop. they said that they might not be able to rethread it because the turbo housing is stainless steel.
hosbaldosho
