Injectors
Markus
Ottawa, Ontario, Canada
I have my intake off and I want to remove and inspect the injectors. According to SHO Shop, the injector O-rings are no longer available from Ford. Is this so? If I am careful removing the injectors am I likely to damage the existing O-rings?
rangerj
Brunswick, Ohio
Markus,
It is possible to remove the injectors from the head and from the fuel rail and not damage the "O" rings on either end. BUT, it is a risk.
Just what is it that you want to inspect. everything is internal, other than the electrical connections.
It might not be a bad idea to have them cleaned and checked by someone who has the equipment to do that. However,I would not remove the injectors until I had a new set of "O" rings.
If I remember correctly, DANA makes an aftermarket set. Follow the other threads regarding the OEM "O" rings, and maybe you can get in on the "group" buy! rangerj
Yamaha V6
SHO Enthusiast
Rhode Island
I found an aftermarket source of o-rings & injector seals, and will be trying them this week as I put my s/c'd 91 back to stock for the smog. We'll see how we make out.
munkee
Too busy...
Missoula, MT
You can get the injector to fuel rail o-ring over the counter at a parts store. Just take in an old one for them to size. The injector to head seal can gotten from ford, 9 bucks for a pack of six. Part number is E9DZ-9C991-A.
recently posted on the LSSHOC list:
Here's the numbers for replacing all the fuel injector rubbers.
Quantity 2 Fel-Pro # ES70600 = $4.30
Quantity 6 Ford Part # E9DZ-9C991-A = $7.80
Quantity 6 Mazda Part # 8574-13-252 = $11.70
Off Road SHO
Moderator
Well,the part number E9DZ-9C991-A doesn't look at all like the stepped rubber seal that is on the injectors. They look like rubber donuts. I wonder if the pressure of the fuel rail squishes them into the stepped shape?
Maybe these donuts are the dust seals for the rail end of the injectors?
Anybody have a Denso catalog so maybe we could find out if these injectors are used in any other vehicles?
Tom
hosbaldosho
