I'm reborn!!!!....Idle woes are gone!...Yippeeeee
Vito117
Iowa
Well after changing the coil pack, new plug wires, new plugs, new IAB valve, new oil seals, gaskets,...I thought that would have fixed my damn idle and stalling woes of so long.......but it took one more step.....
Only took 1 year to finally get this puppy nailed!
I finally took the whole intake manifold apart, cleaned the **** out of it, cleaned the nostils of the EGR and IAB....they were clogged alright!
Then cleaned the **** out of the MAF and its sensor( very gently) I was playing with the valve door, while I had it in my hands, and noticed how it was getting sorta stuck on the gunky crap all over. Cleaned it up , and all the little nostils.
I got **** on all the parts. Scrubbed and sprayed, wire brushed the **** out of the parts and tubes.
Put everything back and by damn it idles the way it should- around 900 or so.
Also noticed SHO is lots more peppier. I did add some injector cleaner into the gas tank. Hope this is OK.
Im so glad I did the clean out job because I getting very pisssed and ready to buy and install a new fuel pump, CPS, CIS, ...who knows what else.
I feel lots better guys!
Now about the that front end shimmy.....new tires.....AC/ recharge...
shobroooo
