Idle problem
J.L.Gordon
Carlsbad,CA
Just completed my 60k on my93 atx starts and die's,but if i keep my foot on the gas it will continue running and let off it die's.Any idea's would HELP.........THANKS Jerry shrug
sideSHO
East TN
Have you checked for vacuum leaks?If all is good there run your codes and see what you get.Be sure to re-set the idle after any mjor service.
Did you get the spark plug wires wires right at the coil pack?
MyFirstSHO
Guest
CT
Might as well clear this up now, What did you perform a FRONT 60K or an UPPER 60K?
Front= where all the pullies are.
Upper= where the intake and valve covers are.
Tell us exactly what you replaced.
Make sure you plugged the connector for the IAC back in.
The IAC is responsible for maintaining idle. Yours is not working.
revhardSHO
Seattle, WA
J.L.Gordon:
could be an airleak from the intake manfold gaskets, if you reused the old ones. fordpartsnetwork.com carries new ones @12.49 each.
musiccitysho
nashville
My 93 ATX was doing the same exact thing a few weeks ago. I removed my IAC and sprayed the plunger inside down real well w/ carb cleaner, until all the carbon was removed, let it dry reinstalled it and the problem was resolved.
My problem was intermittant at first but started happening more frequently. Try starting the KOEO test and pulling the jumper prematurely to clear the codes, I didnt have any codes, but doing this got my car to start and run until I had a chance to work on it.
Hope this helps.
J.L.Gordon
Carlsbad,CA
sorry for the delay i've got two sick children and haven't had a chance to respond.first off i did a complete 60k upper,lower,new y-pipe all new suspension,new intake gaskets disassembled the intake and cleaned everything and reassembled it with new gaskets.i know i've got my vacuum lines screwed up shame on me for not marking them.i replaced every vaccum and rubber water line and installed a new double core radiator and replaced the bearing's in all the tensioner.again thanks for all and any future replys.jerry thumb
