Come on guys, throw a fellow Mocha owner a bone here. You see that I posted this toppic earloer, and got a few responses, but would like some more input. You asked for some more input as to what was replaced. New gaskets, rings, rod & main bearings, water pump, and a 60K service. The problem is a steady stream of oil running off the lower rad housing. A bad, or inproperly installed camshaft end seal. Do you guys agree??? shrug What about the oil pump, or a leaking oil galley plug?
