I need emergency help now cant take radio out
T
ThatSHOkid
Guest
usually aftermarket radios need a key to be able to be taken out. i guess it is soem type of security feature. i found one the other day i think will work.
1993 White/Tan SHO MTX 95k Miles
[*] Superwhite headlights, reverse lights, and license plate lights
[*] Colgan custom bra from Cincy SHO
[*] Windshield Banner that says "SHO" in Gen. 2 font.
[*] Superchip
[*] Blacked out "SHO" lettering
[*] Sho Shop Y Pipe
[*] Coneless & boxless
[*] Blazertech Super Clear 55w Foglight upgrade
[*] Sunroof Wind Deflector and Vent Guards
[*] Sony 10 Disc Changer
[*] Coming Soon:Tinted Windows, Cold Air
[*] All Possible Options
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
93ATX SHO OFF
Basehor, Kansas, US
If it is detachable face, take that off first. There should be two slots on each side of the radio. When you bought the radio, it came with two metal keys that you slide into those slots. You don't necessarily need those keys, just find something long and that will fit into the slots.(hehehe) Hope this helps...
AIM:FrdTaurusSHO
1993 ATX
K&N Cone
20% Tint
Lisesnce plates: SHO OFF
Pioneer 8000R CD Player
Police Interceptor Badges
Amber "Fishtank" Lights
GTS Blackouts
Colgan Custom Mini-Bra from CincySHO
IPT A-Pillar Gauge Pod with Autometer Gauges
White Filled Body Letering(Thanks to: Stallion's90SHO)
TransGO shift kit
8" Solo-Baric in stock enclosure
94shoboy
south shore, mass, usa
ok, as a loast resort, if you can't get it out, if you can get your fingers behind the outside of the sleeve, you can rip the whole thing out in one shot. the sleeve might get damaged, you can get a new one from crutchfield or kenwood for a few dollars. your DIN fitting shouldn't be damaged, if it does it will be minimal because the metal tabs on the sleeve will bend back before the plastic breaks. the ony problem with this is if the installer bolted the stereo to the back of the console, firewall or floor board. i have never seen an installer who actually does this, but i figured i would mention it.
RStalveyARFF
too many shos
Georgetown, MA
what about removing the double DIN console from the dash, and then bending the clips back? Better yet, get the stereo removal tools at the Woburn or Billerica Autozone, and pull out the cup/coinholder, and then use your hand to pull the head unit out by grasping the back and pulling. I belive that's what I did. FYI, you need to click the cup and coin holders out, to allow you to pull the unit out.
