I just changed my gauges and......
quadmasta
Atlanta, GA
now my clock in my dash doesn't light up anymore at night. Is there any way that I could have knocked something loose inside the clock? I know it's a LCD clock and that means it uses an inverter to "light up" as I said. I plugged the only connector I saw back into the clock and now this.
Help me please!
Brian
Speedy_91_SHO
Toledo, OH
There is actually a small light bulb in there. Dealer item. I believe i got mine for like 5 bucks. You could probally get one at a boneyard. Just remove your clock and take it apart and replace the bulb. Took me 2 minutes once the stealer gave me the right bulb...
quadmasta
Atlanta, GA
Speedy_91_SHO:
a friggin lightbulb is a dealer item? How *** is that?
spazzboy
Montreal, QC
I needed that done as well.
thx.
But I also have the same problem with the radio: no backlighting. Not a major problem since I plan on placing an mp3 player in its spot.
SHOck
Louisville, Ky. USA
It's not ****, it's a demand issue. Ford chose to use a bulb not typically used in automotive applications. Ok, their decision was ****...
If you can find the bulb type code, you can pick one up from some like allied electronics for cheap (compared to stealer).
