I have the SHO ghost smh
SHOYAY
WNY
I just can't figure out the running lean issue with my 92mtx. I've changed (with known good used parts and new) tps, iac, fuel pressure regulator, cam sensor, maf, iat, dis , O2 sensors...and all it wants to do is run lean, constantly getting cel because of it and mileage is crappy, not to mention performance is blah. I have 22hg vac and 35 psi fuel pressure at idle... I'm lost...
zoomlater
Seattle, WA
Have you tried cleaning your MAF or swapping it out for a known good one.
SHOYAY
WNY
Yes maf been changed also, forgot to put that in lol
What codes are you getting? If you have a CEL, there must be codes available to look at.
SHOYAY
WNY
Codes that keep coming up are 172, 176, 326 (egr system has been deleted)
And just yesterday for first time got 211 code.
SHOYAY
WNY
Since you've hit most everything else, perhaps an exhaust system restriction?
Stupid question but would that do that tho? I do have one muffler(driver's side)that doesn't flow good compared to the other one...it has catless y-pipe and stock cat back
NoSlo
SHO Owner
Portland, OR
You didn't mention long ago that you had modified factory emissions control devices on your vehicle.
Tampering with the exhaust changes the resonant frequency, port velocities and timing, gas scavenging, backpressure vs vacuum during valve overlap, etc, which alters the exhaust gasses left in the cylinder vs intake charge at different RPM.
Y4Ys1i7
All those fancy pipes on the top of the engine work in conjunction with the pipes on the other side of the combustion chamber, and a computer, that knows how it is supposed to behave, injecting a particular amount of fuel and measuring the resulting stochiometry needed for catalyst activation.
SHOYAY
WNY
So everyone who put a catless y-pipe on were running a lean afterwards?
I found a partial problem to the lean running... pulled out new o2s to check them and one of them had the tip totally missing, so ordered a couple more new ones.
SHOMON
95 MTX
MEDWAY MASS.
I never had good luck with the Bosch 02 sensors in either my ATX or my MTX.
NTK is the O.E. manufacturer and look identical in size and design as the Motorcraft ones I
put in last year when I was getting 02 sensor codes. They are $2.00 cheaper than the Bosch
on Rockauto.
itwonder
VA
You can check exhaust system back pressure with a gauge that taps into the 02 sensor bung. Are your fuel injectors the correct ones? We're running Denso O2 sensors, FWIW.
SHOYAY
WNY
Fuel injectors are factory. Haven't had chance to drive it since putting new O2 in, will be driving it Sunday
SHOYAY
WNY
Put the new O2 sensors in last week and finally got to drive it yesterday, and still running lean smh.
