How do you hook up an aftermarket head unit with the factory amp. I'm not interested in the sub amp as I have already removed the sub however the would like to utilize the other amp. I bought the connections for the back of the head unit. There are RCA jacks that go into the head unit. There is a pair of white/gray and lavender/turquoise. On the back of my head unit I have outputs for the front, back and sub. Which ports do I plug into the back of my head unit. Also which sub wires do I connect and disconnect? I can't get anything to work unless I disconnect all the sub connects in the trunk and run the head unit without any factory amps.
