how to determine my crank sensor is dead?
NoSlo
SHO Owner
Portland, OR
Here's a thread that has some info about the pinout and testing the crank position sensor:
https://shoforum.com/index.php?threads/crank-position-sensor-testing.139383/#post-1515344
Remember, the car has two spark plugs per coil, so you won't easily see spark by just disconnecting a wire, spark will go through the other plug.
Roxyphpimagehttps3A2F2Fiimgurcom2Fckmx2iP
The failure mode of crank sensor is often that it seems to slowly die, failing only when hot. The first clue would be thinking about how your car went from running to not.
In the car, if you have a helper to turn the key and crank the engine, you can monitor the output of the sensor at the DIS ignition module pin #4 with a meter. There should be 12v pulses on the PIP:
Zd97jKp
Also there, one can see if the ignition module is getting the SPOUT signal from the ECU, and if the coil fire pulses are being sent.
There is a second PIP signal sent by the CKP to the ECU, you'd have to backprobe the ECU connector or use a breakout box to monitor there.
BaySHO Performance
SF South Bay
First off, pull the codes and see if you have a 14 or a 211. Both would indicate a PIP circuit failure, indicating a bad CPS. Most likely cause is the water pump leaking on it, shorting it out. I've never known a CPS to 'slowly die'. the car stalls as soon as it gets wet:
http://wiki.wikisho.com/wiki/EEC_Self_Test_Procedure
If no codes, run the Probst DIS tests.DIS Test P1 DIS Test P2
tompumped
VT
Diagnostic flow charts are the easiest way to properly determine whats really happening. A breakout box and IIRC an evtm is the way to go, but the procedure was posted above.
The one huge factory Ford manual I got covers all 1992 fords and is filled with disgnostic flow charts. It makes it so simple anyone can do it.
Harp96sho
Linglestown, PA
You can also monitor the MIL while cranking. If the MIL turns off during cranking, it is "happy" and sees the signal from the crank sensor. It looks at other things as well, but that would be a clear indicator if it is working.
Schiv1010
