2010 No crank after injector install.
bertman7807
tennessee
Hello everyone. Yet again I am stuck with this car. I replaced the fuel injectors and it barely clicked over before doing nothing. No crank and a battery, temperature, and oil symbol on dash. I pulled it back down and verified my work to make sure I hadn't crimped a wire on the fuel rails or anything. When I put it back together it started and ran perfectly. I test drove it and concluded it was fixed. The next day I drove it and the oil symbol kept appearing. Then it did the same no crank. Forscan showed PCM loss of communication along with a host of other stuff. I had to leave it where it was. Today I went to get it and it started up and drove flawlessly home but with the oil symbol again. My thinking is that is could be wire harness related since I moved it both times removing the intake. Does this seem a reasonable assumption? I havent decided where to get to the PCM to check the connection yet. Any input or thoughts would be greatly appreciated. I cant seem to keep this car on the road. It makes it hard to enjoy.
a weak battery will cause a whole bunch of symptoms and codes, making a perfectly good system appear like a wreck.
if the codes are generally of the Uxxxx variety, that is what i would check first. check the knock sensor wiring. a trickier one to track down is loose wiring pins tho have not seen this before the 2015MY.
use a digital tester like the solar ba9 to measure state of health. also, leaking batteries have been known to damage wiring beneath.
no crank can also be caused by PATS issues. usually a dead fob.
i am assuming the fuel is good not gummed up. but it should still crank.
pcm connections are by the passenger strut tower. attached to the firewall, you will see 3 big sidebyside connectors. you can see if they are dirty/corroded.
bertman7807
tennessee
Ok I put a new battery on it. It is random. May start just fine and then it wont. I checked the connectors and they look fine. I'm getting a lot of U codes. Like U0100. I think the PCM is losing power or ground. What are the pins I should check when its not working?
FIREMT1977
