Help!!!!!!!!!
lunchbox0029
Fort Worth
what is the part in the oil pan by the crossmember under the motor . It had one wire going to it and if you take it out oil comes out its long takes like a 1' socket to get out I'm looking for the oil pressure switch it not by the oil filter. 95 ATX 3.2:confused: :eek:
Ishodu
Your looking at the level sender not the pressure switch, Did you remove the clip that holds it in? If so you better put it back in. Here is a pick of the pressure switch. Well that plus another line but it will give you the area.
