Help!
91 Plus
Well-Known Member
Monroe,Michigan
OK I just got my car back a few days ago from getting a rebuilt trans and shift kit!!Well tonight on the way home 200 miles on the new trans I am crusiing on the eway..I get on it to get over and car felt like it went to first gear(i am going 70) and just ****** the car like crazy and then booged out and wouldnt go anywhere..Well a few minutes later the over drive button on the dash starts blinking! MY button on the shifter has not worked for 2 years!! How did this light come on and what does it mean by blinking?
93nighthawk
Mitchell, SD
Pull Codes, The flashing OD light indicates that there was a code sent. I also believe that it means that you lost your OD due to the VSS going bad (or less likely, you lost your OD). But sense you just had it rebuilt, take it back and let all **** break loose.
Eric
91 Plus
Well-Known Member
Monroe,Michigan
Within 4 months i have had 4 rebuilds!!I was lied to and found out 6 months later there was not a shift kit in there that i paid for!!This is getting ridiclious!!
Bizzy
94ShoATX:
Ryan...I don't know what to say man. Your luck with these tranny shops is really bad. There are 2 tranny shops up here that I would like to refer you to if you wanted to come up. One is Beatty Trans in Troy on Rochester Road north of Big Beaver and the other is the Trans Exchange over by Universal Mall which is the Dequindre and 12 (or 13?) Mile road area. Trans Exchange did my clutch work but I know both owners and they are more than honest places to get an opinion on yours. Just an idea.
Mr Anonymous
Tire Wall
Oh man, you just can't seem to get a break with this thing! :(
Normally it would be as simple as a trip back to the shop with an irate look on your face, but with the problems you've had with this shop, I'm not sure that would do you any good at this point...
With regards to the characteristics of the shift kit, you should see relatively the same shifting as without the SK when accelerating 'normally' (i.e. steady, gradual accelerator application), except for a slightly firmer shift on the 2-3. When accelerating hard from a stop, 1-2 and 2-3 will be quite firm, with enough of a slight negative g-force effect to just start your back away from the seat before the shift is complete; but NOT a clunk or a slam into gear. Downshifts at speed should feel just about the same as without the SK.
From your description of the downshift trouble you describe, I suspect a valve body problem. The SK install instructions as pretty idiot proof (there are even pictures), although it's possible they missed a spring or checkball somewhere, or as someone else said, they might have installed the blue #2 accumlator spring instead of using a stock spring. It could also be as simple as them not properly re-torqueing the valve body bolts several times.
You might try taking it back to them yet again, but this time bring a filled-in small claims court complaint with you and demand satisfaction within say 7 days or you'll sue them (and be ready to follow through). I recommend bringing the car to them all warmed up, and make the manager go on a 20-30 minute drive with you to demonstrate the problems.
Mick
Missouri
Man..what terrible service.
I agree with SHOooo. Take it back and DEMAND that they get it right or you will be forced to "examine your options" by seeking legal representation!
They will know what that means!
I forgot that was you with the tranny shop fiasco. Sorry to hear it still hasn't done the job right. There's no telling what has and hasn't been done to that thing by now. I wish I had a good answer for this one.
91 Plus
Well-Known Member
Monroe,Michigan
It is absoutley ridiclious that I have had this many friggin problems!!I would take it to another place but yet again i am 19 years old and dont have another 2 grand to fish out!!!
About the downshifting it does it so damn hard I am afraid i am gonna have the friggin motor fly through and hit me!!I wish someone from around michigan/ohio area with a shift can get together and see the differences...Anyone?
Bizzy
Ryan, the way you describe it, something is amiss. Both Beatty and Trans Exchange will test drive your car and do some checking on it without charging you for it.
If there is something wrong with the trans, the other shop should have to foot the bill. This is INSANE that you should be going through all this.
Here's a few other contact numbers that you may want to keep handy.
Rodger James, Director
Bureau of Automotive Regulation
Michigan Department of State
Lansing, MI 48918-1200
517-373-4777
Toll free in MI: 1-800-292-4204
Fax: 517-373-0964
Margaret DeMuynck, Director
Consumer Protection Department
Macomb County
Office of the Prosecuting Attorney
Macomb County Administration Bldg
One South Main Street 3rd FL
Mt. Clemens, MI 48043
586-469-5600
586-469-5350
Fax: 586-469-5609
Also see this web site
Specifically see this page
Online complaint form
The point is...you have recourse...persue it! I'm here to help if needed.
<small>[ September 15, 2002, 11:33 AM: Message edited by: Bizzy ]</small>
Bizzy is on the right track. If you try to get some remedy from these people you will need some professional opinions about the shifting. Also, you may want to speak to an atty. about legal remedy -maybe a cheap consult to outline what you need to have in line- for small claims or regular court.
GUY L
NORTH COROLINA
I had my trans rebuilt a little over 2 years ago at amco and have not had 1 problem with it and amco has a really good warenty.you should do wheatever it takes to get your money back.
