StAnGbAnGeR
NavistarEngTec
I finally purchased my very first SHO. I'm an ex- Ford Mechanic, so I have
some knowledge of these cars. I just purchased this SHO today. I drove it
home from where I purchased it. The owner did tell me that the car has an
occasional issue no start issue. He said if you drive the car, get it warm,
shut it off and come back about an hour later, it has trouble starting and
idling. When I first looked at it, it had a hard time starting. I found
that when I got it to run, gave it some gas, it stumbled for about 30 seconds
or so, then cleared up, and idled fine. The car seems to have a stumble to it
under heavy load, and more noticable coming in at around 3500 RPM. So I
made about a 40 mile trip home with it, and now I can't get it to stay
running. He's replaced the fuel pump 4 times, and still having the same issue.
On my home, taking off out of a toll, I gave it some, and it started to
stumble. Also I noticed that when I sat at a light, or at a toll at idle, the car
would initially stumble a bit when taking off with a light load, then clears up.
Any ideas? The car starts, runs rough, then wants to die. I'm thinking its a
fuel related issue, but I don't know these SHO's too well yet. It's a 1993
SHO, MTX 5spd with a 3.0L. Any help, would greatly be appreciated. This is
a daily driver and project for me....as I've always wanted one. The car ran
great at cruising speeds, it just seem to stumble as I pushed the throttle
down more. MAF maybe?
