headlight bulb replacement
TDS-MN
Minneapolis, MN
Hey All,
Going to need to dive into this project. Can I effectively get access to everything, to allow me to swap out HID bulbs, if the car is parked flat on the ground? Or do I need to elevate? From youtube videos it looks like I have a fair amount of dis-assembly to get past the bumper cover and to the back side of the headlight housings. Any advice from someone that has been thru this task?
kryptto
South East, Florida
Hey All,
I prefer to dropped the bumper.
Sent from my SM-T860 using Tapatalk
Nova
US
I just changed but of my bulbs last weekend, and the only 2 things I removed to get easier access were the filter on the drivers side and the tube going to the throttle body on the passenger side. It was a little difficult getting my hands in there, but it was definitely quicker than removing the front bumper.
Sent from my SM-S918U using Tapatalk
TDS-MN
Minneapolis, MN
Yeah my hands are too big :(
This is what I was finding also. Very difficult access. Will need to look at what's needed to drop the bumper cover more closely, I had hoped that was NOT the necessary means. But pulling the throttle body tube and stuff did not look very easy either. Maybe a day when it's not 90+ degrees in my garage I will have better luck.
kryptto
South East, Florida
We have people here on the forums - born mechanics/postal type workers - nor snow sleet rain, or super disgusting weather will stop them. Also don't sweat the taking apart of the easier parts. I have removed all those parts they aren't that hard - however time consuming I found dropping the bumper easier, BUT can be a 2 person job when putting it back on, just someone to hold it in position.
See attached :)View attachment Bumper Cover - Front (Front Bumper Cover _ Fascia) - ALLDATA diy.PDF
TDS-MN
Minneapolis, MN
See attached :)View attachment 87297
Ooooh, Thanks for the file showing procedure for removal. That will speed things along I am sure.
BHump1
cincinnati,ohio
Ok, bumper cover removed. now how does headlight come out? Ps... I'm setting on the couch, trying to get ducks in a row for a 1 time procedure. thanx '13 SHO.
Texas Marauder
Lone Star State
Headlamp Assembly​
Removal
  1. Remove the front bumper cover. Refer to Section 501-19.
  1. Remove the headlamp assembly upper bolt.
    • To install, tighten to 3.2 Nm (28 lb-in).
  • 1700327256377
  1. Remove the headlamp assembly front bolt.
  1. Remove the headlamp assembly side bolt.
    • To install, tighten to 7 Nm (62 lb-in).
  1. Remove the rivet push-pin.
  • 1700327295439
BHump1
cincinnati,ohio
Thanx for the intel, Tex! Now to chose the bulb/HID with the least amount of maintenance, Dare i ask for suggestions??? Oh, and I happen to have an '03 Marauder also.
kryptto
South East, Florida
Sorry weekend, glad Tex got the steps posted. If you have xenon, bulbs then you can change the bulbs out, for all other lights the beet like turn signal and all outside leads go to headlight revolution.
GTR are awesome turn signals, if you have the led brakelights - no serviceable bulbs, you can switch out license plate and backups.
An9ther good site:
Xenon replacements:
Check out people's signatures too.
Ta2dResqr
Central Ohio
kryptto
South East, Florida
shootinirons
